Can you please tell me how to avoid getting hanged upon converting rmvb? I don’t know why, but the moment I start converting and begin to click the window that has just come out it would just hang. Why does it happen? I have tried converting other videos and it worked. Do you see any problem in my rmvb file? Can you please tell me how to resolve my issue? Thanks a bunch.
Total Video Converter Error!!! How do I keep my PC from hanging?
The problem is not with the software that is there in your machine. The problem is with the video file. You need to notice at which point the conversion stops. See normally playing the video that at that place the video makes some problems or not. If no problems, then you have problems with the software and not the player. Of total video converter can play a type of file then it can also convert it to that type of file or the other for which the plug-in is present. As such try with some other player or converter for the purpose like FLV.
