Touch ID Application Error 0xc0000135
I won’t open the application the popup comes with an application error 0xc000007b. What is application error 0xc000007b? How to fix application error 0xc000007b?
The error occurs when the third party software installed on the computer then they create the conflicts. If the files missing on your computer then also this error occurs.
Steps to remove application error 0xc0000135:
Method 1:
1. First press windows+R it opens the run dialogue box.
2. Now type the msconfig and press Enter.
3. Click on the General tab and select the Selective Startup then under it uncheck the Load startup items.
4. Click on the services tab and check the box of Hide All Microsoft Services.
5. Now click on the Disable All button and click on Ok.
Method 2:
1. First, click on start and type device manager.
2. Now search for yellow exclamation mark for any drivers.
3. If you find the exclamation mark then expand it.
4. Now right click on the yellow sign driver.
5. Now select the update driver.
6. Now it asks you Search automatically for the update driver software or Browse my computer for driver software.
7. Choose according to your convince.
8. After that, you can start your application without any error.
