Touch-screen Smartphone with Long-lasting battery
I am looking for a touch screen Smartphone that has the best battery-life. Can you suggest a likely brand or a specific model that is known to have a durable battery life? What type of battery does this phone use and is this battery readily available to purchase? Where can you buy this particular battery?
Answered By 590495 points N/A #186492
Since you are looking for a Smartphone with the best battery, the Huawei Ascend Mate2 is a good candidate. This handset is one of the Smartphones with the longest battery life. Huawei Ascend Mate2 4G supports 2G, 3G, and 4G networks and uses a SIM card. The handset was announced on January 2014 and released on the same month.
It measures 161 x 84.7 x 9.5 millimeters and weighs 202 grams. It has an IPS+ LCD capacitive touchscreen display with 16M colors at 720 x 1280 pixels screen resolution. It is protected by Corning Gorilla Glass with Emotion UI v2.0 and supports multi-touch. It has 16 GB internal storage running on 2 GB RAM.
It supports Bluetooth 4.0 with A2DP, EDR, and LE. It is also equipped with microUSB 2.0 with USB Host and USB On-the-go. The primary camera supports 13 megapixels at 4128 x 3096 pixels resolution with autofocus and LED flash. It features geo-tagging, HDR, panorama, and face detection. It can record video in 1080p at 30 fps.
The secondary camera supports 5 megapixels. The Huawei Ascend Mate2 4G runs on Android 4.3 Jelly Bean powered by Qualcomm MSM8928 Snapdragon 400 chipset, Quad Core 1.6 GHz Cortex-A7 processor, and Adreno 305 GPU. It has gyro, proximity, accelerometer, and compass sensors. For internet browsing, it supports HTML5 as well as Java via Java MIDP emulator.
It runs on Li-Ion 4050 mAh battery and can last up to 14 hours and 43 minutes. It is priced at 330 Euros.
