TP link 8 port router’s features and applications
Hi
These routers are ports for internet sharing locally. It is ideal device or medium to be used at home and for office users. This has IP based bandwidth control. This control allows administrators to determine how much bandwidth is allotted to each PC which guarantees the performance of video application. It has flexible control features. This allows parents or administrators to establish restricted access policies for children or staff. It also supports Dynamic DNS, IP and MAC binding.
This can be used as explained – create a wired network in your home using this cable. Connect this wired router to a broadband modem and share your high-speed internet access, check mail, share files and enjoy online gaming. With easy setup assistant one can easily build a wired network and share the internet access.
A TP-LINK 8-port router is a kind of router that offers 8 ports for internet connection sharing and local area network built by TP-LINK Technologies Co., Ltd., a Chinese company based in Shenzhen, Guangdong that manufactures computer networking products. TP-LINK was established by two brothers Zhào Jiāxīng and Zhào Jiànjūn with a network card they developed in 1996.
The letters TP in the company’s name was based on the idea of “twisted pair link”, which is a kind of electromagnetic cabling. An example of a TP-LINK 8-port router is the TP-Link 8-Port Gigabit desktop switch TL-SG1008D.
It features 8 Gigabit Auto-Negotiation RJ45 ports with Auto MDI / MDIX support, Green Ethernet technology that offers low power consumption up to 80 percent, IEEE 802.3x flow control that offers dependable data transfer, and plug-and-play design that doesn’t require further configuration. It offers a much easy way of making a transition or shift to Gigabit Ethernet and boosts the speed of the network server and backbone connections.
It has 8 10/100/1000 Mbps ports that allows for greater expansion of your network capacity that facilitates instant transferring of large files.
