Trace IP Address on ASP .net Programming
Hello Carolinehuber,
To find out the email address of the email sender.
Follow the below steps:
Copy the headers and paste it to the dialog box on the page of the given link Below :
https://whatismyipaddress.com/trace-email As simple as that.
When we get an email, we get more than just the message. The email arrives with headers that hold significant information that can inform us from where the email was sent from and perhaps who sent it. For that, you would need to locate the IP address of the sender.
It is possible in asp.net programming. By recovering the IP of the tourist of a website is simple by using .NET (ASP.NET); there are numerous motives why you would want to do that. Well, in .NET 1.1 and 2.0 there are techniques in the System.Net namespace that do that.
To track IP address of a system you may follow the step given below,
If you want to manually find the IP address you should follow this,
Look for Received: from followed by the IP address between square brackets [ ]
That should most likely be the IP address of the sender.
If there are many instances of Received: from with the IP address, select the IP address in the last pattern. If there are no instances of Received: from with the IP address, select the first ip address in X-Originating-IP.
