Hi everybody,
Good time. I need ax 2009 crm user guide for learning purpose. Where can I find ax 2009 crm user guide and other training materials? Specially about crm module. Please help me finding it.
Training Materials for AX 2009 CRM User Guide
Hi
After a 2009 upgraded version , we have seen that there is need for Dynamics AX 4.0 power users to have a fast and easy guide to see the new functionalities/features found in Dynamics AX 2009.Please find attached AX CRM 2009 user guide and learning material.New functionalities have been documented in brief descriptive outline with graphical indicators.
Thanks
McNabb
Hello, Kathryn
Hope you are fine.
You can get your ax 2009 crm training material easily. Just go to the link below .
crm training
Here you will find an option to download it. And I can suggest you a link which will take you to the user guide. There you will find everything about ax 2009 cm. Just click on the left side what you want to know.
User guide
Hope you will get your answer.
