Transfer Active Directory Server Roles To Another Folder
Hello everyone, I am in a problem. I was transferring the schema master when I lost some step. Kindly help me in solving the Active directory server roles steps.
Select start menu and type run.
1. As the box appears you have to type regsvr32 schmmgmt.dll.
2. Press Enter.
3. Press ok when you see the successful message.
4. Click start menu, open run box.
5. Type mmc in the box and click OK.
6. Select Add/Remove Snap-in from File menu.
7. Choose Add.
8. Hit Active Directory Schema, click Add, hit close and select Ok.
9. Under console tree, right-click Active Directory and choose Change Domain Controller.
10. In specify name type the name and then press OK button.
11. Hit Change and then OK.
Notifications
