Transfer Email from OSX Mail to Outlook and Vice Versa
Hello Everyone!
I would like to export my OSX mails to my Outlook and even Export my Outlook mails to OSX.
How can I do it easily and hassle-free?
Hello Everyone!
The easiest option probably is to use an IMAP or Exchange service.
If that's not possible Thunderbird is the best option as already suggested.
1. Download & install Thunderbird on the PC (where Outlook is installed)
2. Using Thunderbird, import Outlook files
3. Copy (IUSB drive) the Thunderbird folder containing imported Outlook files
4. Connect USB drive to Mac
5. In Mail, "import mailboxes"
The best way to move your Thunderbird mailboxes to Mail.app on Mac OS X is "Eudora Mailbox Cleaner" – it will import all mailboxes to Mail.app.
Hi I have read a post on transfer Apple mail to Outlook in Mac: You too can go through
