Transfer EMC CLARiion from website to another
I would like to transfer EMC CLARiiON from one website to another. How can I make this possible? Do I have to stop the MirrorView before moving or what do I need to perform this? Please help.
Yes, you will need to pause or even stop the mirrors when you are taking down the array. Once you have done that, you will then bring it up after moving, but you will first have to make sure that the link is up running and stable. I am guessing that the array that you are using will only need to be down for a short time, for instance a night, and that will make it possible for the resyncing process to go well without much problems. In case it will be possible, you should keep the writes on the partner array to a minimum so that you can also reduce on the time taken to resync.
Regards
Thompson Locker
