Transfer file 1GB from 1 remote PC to other.
Want help in order to transfer 1 GB video from one city to another. Please suggest any idea to achieve this in minimum time as Team viewer takes more time.
Sending files online is quite a tough work and if the file is large enough, it is time spoiling, no doubt. Your video file is 1GB which is large enough. In order to send it, you must be patient.
The transferring speed mostly depends on your internet connection. If the connection is fast enough, its uploading speed will be of sky high and uploading will be performed very fast. If the connection is slow enough, this will take time.
If you don’t want to send files using TeamViewer, you can send them by any FTP client. FTP is the best choice of me to transfer files over internet. You have to install an FTP client in your PC. You can use Files2U, FileZilla etc.
