I want to transfer files like audio, videos between my laptop and android mobile phone. I don’t want to use a data cable. Bluetooth connection can be made but the file transfer using Bluetooth is very slow. Is there any way I can share files between my PC and mobile or with any other PC without using Bluetooth or data cable.
points
Transfer files between my PC and mobile fast without using data cables
Data transferring means transferring the bits of the particular file over the transferring method. There are different data transferring method that can be used. Each method has a limitation of its top speed. You can’t exceed it though you try your heart and soul.
As you’re using Android, there are many apps that makes transferring files via Bluetooth super-fast. You can use Bluetooth File Transfer, SHAREit etc.
You can also use USB data cable which makes data transferring faster than Bluetooth. The transferring speed should exceed more than 10 MB/s if your SD card or file storage is on good health.
Also, internet connection can be used to transfer files, for example, via FTP. In that case, you can use AndFTP.
If your SD card is old enough, it can’t support faster data reading or writing which will definitely slow down the transferring speed even you’re using the fastest data transmission technology.
