Transfer files from iPod to another computer
Would someone please tell me how to transfer files from iPod touch to another computer?
I synchronized the files originally to my MacBook and I want to transfer it to my PC.
What I suggest is for you to download ifunbox. It's for me, user friendly.
Here is what it does:
Total Control of iPhone/iPad File System
One-stop App Install and Backup
Hi-Speed General Purpose Storage
General Purpose File Search on iPhone
Export Music and Movie on iPhone/iPod
That's it your done. 🙂
Enjoy and Have Fun!
Yes dear,
its not a difficult task and it is very much easy to transfer files from an iPod to a computer. But my dear, there is a problem that there are many devices of iPods and I don’t know which device you are using and for that every device has a different method of transferring.
Well I am going to tell you the general way and that one is with the help of USB or SD card. If you have an iPod of built-in USB, then you can easily put that USB to you computer port. Otherwise there is a card in your iPod you can put that card in card reader.
