Transfer files using Dell PC suite for Dell aero
I just got a Dell Aero android cellphone and I want to sync it to my computer.
Is there a Dell PC suite for Dell Aero so i can transfer files from the computer to my phone?
Hi Dorothy Davissy,
As you know, from Google you can find a lot of forums but the chance of getting the right solution depends on where you post your problems.
We have so many different forums get Dell PC suite for Dell aero.
So classifying and posting them on relevant forums is the best way to get your answer step by step.
I can suggest you some good forums, which are listed below
2. Get all the manuals for using it
Hi Dorothy,
Yes, you can download the Dell PC Sync Tool application for your Dell Aero Android mobile phone so you can sync or transfer files to your computer.
You can actually download the application from Dell’s site so you are guaranteed that the download site is secured, and the program is virus-free.
Here’s the download link from Dell’s site, Dell PC Sync Tool.
Hope this helps you.
The only existing Dell PC Suite I was able to find is Dell PC Suite v.0.0.48 for Android 2.1 Eclair. I’m not sure if this will work on Dell Aero because the phone runs on Android 1.5 Cupcake. Anyway, if this failed to work on your phone, try downloading Moborobo PC Suite instead. It supports Dell Aero 1.1, 1.5, 1.6, 2.0, 2.0.1, 2.1, 2.2, and 2.3.
Here are the phone’s specifications. Dell Aero is a discontinued 3G Smartphone operating on 2G and 3G network bands using GSM and HSPA technologies. It was announced to the public on March 2010 and released on August 2010 measuring 122 x 57.9 x 11.7 millimeters and weighing 104 grams. It uses mini-SIM card and has TFT capacitive touchscreen display with 256K colors at 360 x 640 pixels screen resolution.
It is protected with Corning Gorilla Glass with handwriting recognition support. It ships with Android 1.5 Cupcake powered by 624 MHz Marvell PXA310 processor. It supports microSD expandable up to 32 GB. The primary camera supports 5 megapixels with AF featuring LED flash and can record video in CIF at 30 fps. There is no secondary camera and no 3.5-millimeter jack support.
It has Wi-Fi 802.11 b/g, Bluetooth 2.0 with A2DP support, GPS with A-GPS support, and miniUSB 2.0. It doesn’t have FM radio. It has built-in accelerometer and proximity sensors. The pre-installed web browser supports HTML with Adobe Flash Lite support. It runs on removable Li-Ion 1000 mAh battery with standby time up to 400 hours and talk time up to 5 hours.
It is available in black color.
