Transfer Location of Save Folders
How can we transfer the location of save folders in OS default drive? For example in "My Documents", is it the same with Outlook Express, Tools> Options> Maintenance> Store Folder> Store Location? Please help.
No it is not the same. If you want to change the location of the storage of outlook files, then simply copying and pasting them to a new folder location is not the right way. Although the current files will be transferred, but if your intention was to change the location of the files as you download and save them using outlook then it will not work that way. You will need to change the location when you download and save on file in outlook and change the folder location for all files.
Regards
Thompson Locker
Nice Thompson. I am benefited by your answer. I have my desired solution now. I am inspiring you to help people like it. Then everyone will be happy. Thanks techyv also.
