I brought new Samsung Galaxy S4 and need to transfer few SMS messages from my old Nokia 6220, Is there any tool to transfer messages from Nokia to Android, please guide me, how to achieve the same without loosing money on SMS forwarding.
In order to transfer your messages from your old phone to Android, you will need a PCSuite for Nokia or some other backup utility provided by Nokia. You will also need a cable to connect your Nokia phone to the PC. Nokia PC Suite can be found at Nokia Support Center at the link.
Once you have it downloaded, installed and running, connect your phone and using the provided option backup your SMS messages to a CSV file. You will get the option to save that file, so save it on your computer.Â
After the backup is stored on your hard drive, disconnect your phone as you don't need it connected any more.Â
To import SMS backup into your new Android phone you will need another software. It is called PC Tool for VeryAndroid SMS Backup and you can download and install it from the link:
After the program is running, connect your Android phone using the USB mode.Â
Click Menu, then Sync and Transfer SMS from Other Phone to Android. Select the backup file from your hard disk and confirm by clicking the Open button.Â
PC Tool is going to load messages on your screen so you can review them before the restore.
Select Restore all SMS to Android and all messages will be sent to your Android phone.
The Nokia 6220 classic is a discontinued 3G mobile phone operating on 2G and 3G network bands using GSM and HSPA technologies. It was announced to the public on February 2008 and released on July 2008 measuring 108 x 47 x 15 millimeters and weighing 90 grams. It uses mini-SIM card and has TFT display with 16M colors at 240 x 320 pixels screen resolution.
Nokia 6220 classic
It ships with Symbian OS 9.3, S60 rel. 3.2 powered by 369 MHz ARM 11 processor. It supports microSDHC. It runs on 128 MB RAM with 120 MB internal storage. The primary camera supports 5 megapixels with AF featuring Carl Zeiss optics and xenon flash. It supports 480p video recording at 30 fps. The secondary camera supports video call.
It doesn’t have 3.5-millimeter jack but instead uses 2.5 millimeter audio jack. It doesn’t have Wi-Fi support. It has Bluetooth 2.0 with A2DP support, GPS with A-GPS support and Nokia Maps, stereo FM radio with RDS support, and microUSB 2.0. It doesn’t have built-in sensors. The pre-installed web browser supports WAP 2.0/xHTML and HTML.
It runs on removable BP-5M Li-Ion 900 mAh battery with standby time up to 250 hours on 2G and 240 hours on 3G. Talk time is up to 3 hours 30 minutes on 2G and 2 hours 30 minutes on 3G. It is available in Black and Cyan and Purple colors.
Now, if you want to transfer your SMS from the Nokia phone to an Android phone, try downloading Mobile Transfer. Another program you can use is Nokia2AndroidSMS.
A Quiet Revolution in the World of Pages
Once upon a time every book left a trail. Bent spines dust jackets that never quite sat right paperbacks split at the seams. Shelves groaned under the...
1....
