Transfer music files from my Computer
Hello Experts ,
I want to know how to transfer music files from the computer to the CD, while using the option CD Burning? Any help with that issue ?
Thanks
Hello Experts ,
Thanks
Transferring the music files to the CD is rather a very simple operation; all you need is a CD burning application. Let’s take an example of the most common application, which is part of the windows software that is Windows Media Player.
All you need is to have the recent version of Windows Media Player, version 9 or above.
After the download and updating are complete, open the media player.
Now insert a blank writable CDR/CDWR/DVDR etc., in the respective CD/DVD Writer.
Now select your music files by clicking the file- open –and select all of your music files.
You will see the selected music files on the media player as per picture below:
Now click on BURN, and simply drag all of your files to the right side of your media player, where it is written “Drag Items here”
And presto, your music CD/DVD is being written.
James
To transfer a music file to the CD, using the CD Burn, you simply have to insert the CD in the CD drive and then take off the CD burner and choose the disc you want to burn. You say it is a music file, so choose the audio disc and then click the type of disc. Now click the CD disc and select the data or file to be burned to your CD. Click the minor image overhead and then burn to a physical CD.
Lastly select the media from the list of options and then click the okay button. Wait for several minutes and then after burning just simply get the CD to your CD drive.
