How to transfer photos from computer to mobile phone
I have a desktop personal computer where I am using XP operating system, and I have a phone Nokia 5130 model. I have a memory card and a memory card reader. When I put the card by adapter the computer recognize it, and the picture that I have on my phone can transfer to the computer with no problem. But the picture on my computer won’t transfer to my phone. All that shows up is a big error.
How can I transfer the picture on my computer to my cell phone?
Best Answer by simonjones
Answered By 0 points N/A #118421
First let me clarify that it doesn’t work the way you do it because you have to specify in the Memory Card where you have it not just draw it to the memory card Icon.  Secondly, you need the Application Software that came with this specific Phone, Nokia Ovi Suite is the name of the application you can also download it from the Nokia Official Website.  This is because the software formats the picture to the specific format that the Phone supports.  Once you have the software, Select the file or Photo you want to sync to your phone. And Select Copy to Device from the menu that appears.  And the process will then start.  IF it asks you to Click Sync or ok, Click on it. Then at the end select Finish or Done.
Answered By 0 points N/A #118422
Hi Sinthiamem,
  • I hope you are fine. The question you have asked is about file transferring from your computer to your mobile. You have mentioned that it fails due to some reason. Though you have not mentioned what kind of error it actually gives; yet I will suggest you a solution that might be helpful for you.
  • When you connect your mobile device with your computer through data transfer cable, it shows three different options, file transfer mode, Nokia PC suite and another one I don’t remember. Now when it asks you about selecting the mode, select file transfer mode, which will allow you to transfer the files into your memory card as you are using a USB drive. You can conveniently transfer your data through this method.
Thank you
