Transfer ps2 convert to pc online for remote gaming with more users
How do I transfer ps2 convert to pc online in real-time to ensure remote gaming with more online users locate in different locations without any delays or setbacks to any given player at any given time?
Best Answer by Leslie Mark
Answered By 0 points N/A #194903
Hello Berthapearll,
You can use your PS2 controller to play online games on you PC. In order to do that you would require a lead that is attached to the controller which converts it into a USB controller which can then be connected to the PC.
I have attached a picture of what that lead looks like, you can find it on www.ebay.com Another way out is to just buy a PS3 controller which comes with the lead and you can connect it directly. It would cost you around $5.
Answered By 0 points N/A #194904
To transfer ps2 game converted in pc at first you need to convert them and then you can share online.
You can now play ps2 games to your pc easily. Generally you can use just download emulator & install it to your pc. Enjoy!! To download: The Emulator Zone – Playstation 2 Emulators
Or you can follow as below to play ps2 games in pc.
Step 1 >> Download and install DVD Decrypter
Step 2 >> Now insert your ps2 game Disk to pc & wait for synchronize.
Step 3 >> Now select "MODE" and Click on "ISO".
Step 4 >> Go to My Computer & you'll see a new removal drive (It is your ps2 game ISO file).
Step 5 >> Right click on the ISO item and Select Open Autoplay.
Now enjoy your favorite ps2 games on your pc.
Answered By 0 points N/A #194905
Hellow Bearthapearll,
You can play online games via data stored on PS2 memory card by using a converter. Please follow the procedure.
  • Buy an Official Sony PS3 Memory card Adapter
  • Insert your PS2 Memory card into the adapter.
  • Select the Memory Card Utility (PS/PS2) under Game menu
  • Press the controller's Triangle button to get the Memory Card Option
  • select Copy
  • Choose Yes
  • Enter a name
  • Select Ok
  • Make sure that new internal card showing in XMB
  • It must be assigned to a 'slot'
  • Then enjoy the game
Thanking you
Shifflett Laurel
