Transferring a code to c# when coding for vpn
have got this c# code copied from some site, am supposed to use it for coding for VPN on my girl friends computer away from my home server but am not sure of the steps to follow. i need some help.
Answered By 5 points N/A #171345
All you need is a remote desktop connection not a VPN. Creating a VPN is a bit costly process. You can easily achieve what you need remote desktop connection software like Teamviewer . Both parties involved in the connection should have the same version of Teamviewer installed. Latest version of the Teamviewer is 7.0. After installing the software double click on the icon on the desktop then you’ll see a ID tell that ID to your friend then your friend need to type it on the partner ID textbox and click to connect. Then your partner will be prompt to enter a password. Tell your password to friend. Once she enter the password and press enter she’ll be connected to your computer and she’ll be able to do any work on your computer. Just do the process other way around if you need to connect to her computer.
https://www.teamviewer.com/en/download/windows/
