Transferring Photos Or Any Others From Our Mobile Phone To Pc
How can we TRANSFER PHOTOS and folders from our daily usage mobile phoneto PC, if we are near or not near to our computers?
There are various ways of transferring Photos & files from any mobile phone to any PC.
The methods are as follows:
Method 1:Bluetooth
This is the symbol of the Bluetooth device with which we could connect to any device and share photos and files. There are a few steps to be followed to TRANSFER PHOTOS/FILES through Bluetooth.
Step 1: Activate the “BLUETOOTH.”
Step 2: Select the device with which you need to share/transfer Photos or files. (Then a pop-up comes asking whether to pair with the specified device or not) Step 3: Click on the pair button.
Step 4: Once the is device paired with the PC then you can transfer Photos/Files etc. Once the device is paired you will see something like this:
Method 2: USB Connection
“USB” stands for Universal Serial Bus. With the Help of USB, we can Transfer and Share Photos/Files In a much faster way. Has the USB is a wired connection between the PC and the mobile phone the Photos/Files transfer will complete in very less time. There a few steps to be followed to transfer the files using the USB.
Step 1: Connect the USB wire to PC and the mobile phone. (Once we have connected the USB to the PC we see a Pop-up as shown in fig below)
Step 2: Click on the Pop-up “Connected as a media device”.
Step 3: We need to select the type of the Transfer we need.
Step 4: By opting the “Media Device (MTP)”. We can select Photos/Files and transfer them.
Method 3: Sync If our mobile phone is associated with our PC, we can “Sync” the photos to our PC and Transfer Photos/Files through PC.
There are a few steps to followed:
Step 1: Connect the computer and mobile phone to sync.
Step 2: Choose the Photos/Files to be synced.
Step 3: activate Sync
Step 4: Select which type of sync we want to use to Transfer Photos/Files.
Once we select the Type of Transfer, we can Sync and Transfer Photos/Files. There are many other Methods also
Method 4: Drop-box
Method 5: Memory card transfer
Method 6: File sharing apps such has: Share it, Xander, Super-beam etc.
Notifications
