Transferring recorded shows to Apple Laptop
Hello Zarah,
To transfer DVR to your Mac laptop, you must download software that captures and edit video from your DVR to computer; via USB, infrared or Bluetooth will do. I will recommend the AVS Video Converter. free download from here
After that, install AVS on your Mac laptop. You should connect all the cables, and then press the play button on your DVR and on your AVS Video converter, click the “next” button to start recording the video stream real time. When it is finished, feel free to do simple edits; you can convert it in other video-formats to be viewable devices such as PSP, Ipod and other Media Players or you can burn it to DVD.
I hope this helps!
Notifications
