Transferring videos simultaneously from Nokia mobile
I want to transfer my videos taken with my Nokia e63 to my PC. The trouble is that the cell phone didn't come with a cable. The connections I can use are Bluetooth, and WiFi. I already tried the WiFi, but it only allows me to transfer one picture at a time. I want to transfer 436 photos at once. Suggestions please.
Answered By 5 points N/A #109354
To transfer your stuff (videos,photos, music or anything) from your cell phone to your computer, you can go for following ways of connecting:
1. Using a data cable (which in your case you don't have it)
2. Transferring your stuff from the memory card of your phone to your PC with the help of a memory card reader. In this case you will just have to insert the memory card of your cellphone (by making sure all the 436 photos you want to transfer are present in your memory card) & transfer the stuff from your memory card to your PC by simple drag and drop method.
3. The third option is to transfer the contents of your Nokia phone to your PC through Bluetooth connection. In this case once you have successfully connected your Nokia cell phone to your computer through Bluetooth, open the Nokia PC Suite. Click on File manager as shown below:
Nokia PC Suite
Filemanager of your Nokia phone would be opened, there in you can locate your photos etc which you want to copy, select them all and copy them from your phone to your computer.
