Transport an AD LDS instance from one machine to another
Hello Marsha,
Follow the instructions below to be able to solve your problem:
For more information, Check on this forum using this link I hope it helps.
Have a great day.
Zorian
The AD LDS instance on one computer can be replicated on different computers but it should be from within the same network or local area network.
To replicate the instance started on one workstation to other computers on the network, the AD LDS setup wizard should also be executed on those computers. This is needed to install a copy of the AD LDS on the target machines.
This is the only way you can replicate or copy the instance of AD LDS to other computers on the network.
The setup wizard provides the option to replicate or copy the instance to other computers within the network.
Notifications
