Toby Malone
40 points
Posted on - 02/05/2013
I am getting this error while trying to install trend micro antivirus security program. It gives the following error every time I try installing it. Does anyone know what can be the reason behind.
Trend Micro Titanium Internet security 2012 Incompatible software found Please try to install trend micro titanium security 2012 again after removing the following programs from this computer. Incompatible software: SUPERAntiSpyware
Trend Micro Antivirus Error Incompatible Software
Good day Toby,
Before you can install Trend Micro Antivirus Software, you need to uninstall first your SUPERAntiSpyware program. You cannot install Trend Micro Antivirus unless you would remove the SUPERAntiSpyware already installed in your system. After you have removed/uninstalled SUPERAntiSpyware, re-install again the Trend Micro Antivirus Software.
Hope it helps,
Korber Owen
Hi Toby,
The reason that your unable to install Trend Micro Titanium Internet Security 2012 is that a program, which is already running/installed in your computer is not compatible with the program you are trying to install. You need to close the notification window ( Trend Micro Titanium Internet Security 2012 window), then uninstall the program named "Superantispyware". If your using windows click "start menu/control panel/programs/programs and features then uninstall it. Then try installing Trend Micro Titanium Internet Security 2012. If the problem still insist and the notification window popup, click "Get more information on system requirements" then follow the instructions.
Hope it helps,
Llison Janneya
