Trend Micro Titanium Internet Security 2012 Incompatible Software
I am really fed up with this error appearing on the screen while trying to install the Trend Micro Titanium Internet Security 2012.
Kindly provide me the solution to fix this issue.
Please see the picture below to see the exact error.
Thank you.
Error:
Incompatible Software Found
Please try to install Trend Micro Titanium Internet Security 2012 again after removing the following programs from this computer.
Incompatible software:
SUPERAntiSpyware
Answered By 0 points N/A #149307
Dear Kim Brauer,
I am very sorry to inform you that Trend Micro Titanium Internet Security 2012 is a kind of application that will not accept other
Antivirus or spyware running when it is going to work.
It does not allow other Antivirus or Spyware presence.
So its clearly you need to get rid off that SUPERAntiSpyware software.
Here is the process to uninstall it :
Step One – StartMenu > Control Panel
Step Two – Add or Remove Program > Double Click on "SUPERAntiSpyware"
Step Three – Uninstallation will start, you just need to follow the instruction.
