My Windows 7 computer originally had a Trend Micro Titanium Maximum Security 2011 version 3.0 installed on it. However, after installing Service Pack 1 on the computer, I encountered a problem in reinstalling Trend Micro Titanium Maximum Security 2011 3.0. It does not install and instead, gives out the error code: #0, 3002, 0x000. Please see the attached image for the exact error message.
Error:
Installation Incomplete
A problem prevented the installer from completely setting up Trend Micro Titanium Maximum Security. No changes have been made to your computer.
Please close any otherprograms currently open before restarting the installer.
If following this advice does not solve the problem, you can also get more help online.
Error code: #0, 3002, 0x000)
Trend Micro Titanium Maximum Security Installation Incomplete Error Code 0, 3002, 0x000
It’s unwanted but nothing exceptional to facing problem to install/reinstall Trend Micro Titanium Maximum Security. Here I discuss something about your solvency. Hope this may work.
Before you reinstall Trend Micro Titanium Maximum security, you have to remove some program from your PC. They are, 1. MS Outlook.
2. Outlook Express.
3. Windows Mail.
It has to do because of your desired software installation features on some program.
After closing this I mean, remove this program, you can reinstall your Trend Micro Titanium Maximum Security on your Windows 7.
If this doesn't work, you may visit the site for a proper remedy-
TREND MICRO
How to uninstall my Trend Micro Titanium 2011 product using the Trend Micro Diagnostic Toolkit
If the process in the site doesn’t work again, then you have to remove Trend Micro Titanium Maximum Security from your PC and redownload it and reinstall it. Visit the site for then instances
Hope this all can serve you a better relief.
