I want to install Trend Micro Titanium Security for Netbooks 2012 on my Acer One netbook but I want to know first what are the minimum requirements and what programs do I need to remove before installing it?
I need advices.
Thank you.
Trend Micro Titanium Security for Netbooks 2012 Requirements
Here are the minimum requirements for Trend Micro Titanium for Netbooks 2012:
For your Operating System (OS) you can use:
Windows 7  Family  (32 or 64 bit)
            CPU: 800 MHZ but 1 GHz is recommended
           Memory: 1GB
           Disk space: 400 MB
or
Windows Vista Family  (32 or 64 bit) Service Pack 2 or Higher
            CPU: 800 MHz but 1 GHz recommended
           Memory: 512 MB but 1 GB recommended
           Disk space: 400 MB
or
 Windows XP Family (32 bit only) Service Pack 3 or Higher
             CPU: 350 MHz but 800 GHz recommended
            Memory: 256 MB but 512 GB recommended
            Disk space: 400 MB
For your Internet Browser, you can use the following:
Microsoft Internet Explorer 7.0, 8.0 or 9.0
Mozilla Firefox 3.5 or higher
Google Chrome 10.0 or higher
For your Display or Screen Resolution:
800×480 pixels or higher
You can change the setting by Right-clicking on your desktop, and selecting Screen Resolution,
And changing the Display Settings. (screenshot from Windows 7)
You also need any PDF Reader to view the User's Manual and other documents provided by the software.
You can get the PDF Reader here:Â
I hope this helps. 😀
