“TR_FG16e OVERSPEED ERROR” with CMM
Hi
My associate's CMM is not running well. I have some experience with the CMM and the following is a depiction of the error problem.
In first the B&S PFx CNC CMM, the machine and computer are opened.
The PC-DMIS 4.3 software is running.
Then the probe and stylus combination are established.
The PC DMIS prompt states “Do a machine start (if needed), then press OK to home”
The green “MACH START” on the controller is dejected and indicator light runs.
The “OK” button is selected.
The grey activity bar of the screen instantly shows the following error code.
Then I switched off the CMM as well as the computer a number of times. Then I restarted them both and every time had the similar error message.
Thank you for your supports in determining this problem.
We have to find something to happen in a support feature. Please give me any information so we are able to get this machine back up and working.
Please help. Thanks.
