I had install Trial version of Corel Draw (R) Graphics Suit X5 1 month back. I am using software for 12 days from installation.
Then some serious error occurs in software. So I decide to Uninstall this application. I start uninstall process – control panel –Add remove programs – but I could not Remove this software. Then I start to reinstall this application but it could not work.
So How to solve this error from my computer?
Trial version software cannot uninstall from Add remove program (Control Panel)
Good day! Kartik
You asked a worthy question about your uninstalling error. Sometimes it happens that one tries to remove particular software from the OS through “Add/Remove Program” but the operation get stuck in the middle or give an error. There could be different reasons for it. There is a possibility that the installer package was not installed correctly due to some faulty error in it, and because of that it damaged the OS registry. Or it might be possible that there have been an error already in the OS registry and the program was not installed properly.
I would suggest you to go to your “program files” and find the particular software folder and get it deleted manually and afterwards run a window registry scan to solve the issues in it. “Ccleaner” could be a good choice for this. If it does not work, get good uninstaller (Revo uninstaller, Your Uninstaller, Easy Uninstaller) software and instead of using OS Add/Remove program, use the uninstaller software to remove your package from your PC.
Thank You
Here is what you will need to do to remove that application from your computer.
First, you will need to go to C:Program Files and then locate the folder that has that application.
Open the folder and then get rid of everything inside it.
After that, go to start on your computer, and then locate control panel and click on it.
In the window that will open, click on programs > programs and features.
After that click on Add/Remove programs, and then in the list locate that application and click on it.
After that click on remove or uninstall.
Hope this helps.
Carl
