Hi all,
One faces many situations where we want to delete a publication. I wanted to delete a publication but the content management system installed on my PC shows an error. I am using the Tridion content management system. The screenshot of the error is shown below:
Tridion R5
It is not possible to delete a Publication that contains published
items.
I am trying to understand what this error means but I cannot get the point.
Has anyone else faced this problem with Tridion? What is the root cause of the error?
Any help will be highly appreciated.
Regards
Edison
Tridion R5 strange error message
I am not familiar with Tridion or any other content management systems [CMS] but upon searching the web I managed to find a blog that completely explains on how to properly delete a publication under the Tridion content management system.
It is clear in his blog that you really can not delete a publication if it is still currently published and the publication should have no other dependencies or any child publications within the publication. This means that you need first to unpublished the publication before you can actually delete it. It also suggests a different way of unpublished all items by running the following query on the CM database [but do backup the database first before continuing with the procedure]:
To understand how it is properly done and to visit the blog as well, you may visit Albert te Boekhorst — How to delete a publication from Tridion.
