winnie zac
90 points
Posted on - 07/11/2012
Hello techyv! I have a problem,
I can't set an avatar on my upgraded version of Trillian 5.1.19. It won't let me use my own photograph or one of the ones that come with the app. When I do try and set the picture it just says “pending”, then the next thing that happens the picture disappears and I'm taken back to the original Trillian icon. Do you know how I can solve this? It won't let me set my avatar/icon.
What could be the problem? Any help will greatly be appreciated.
Trillian Won’t Let Me Set An Avatar
I have recently encountered the same error regarding to that Trillian. If you haven’t tried to restart Trillian, do that. Sometimes it will fix the problem. The solution that I did was I remove my twitter account from Trillian, then I shut down Trillian, after that I restart Trillian, then I re-add my account info, then it worked for me. If still doesn't work for you, re-installing may fix the problem. You need to check also the network since “pending” only appears, so might be a problem with your connection. Close other any program to test if some program might be the cause of the not responding.
