tomas rular
10 points
Posted on - 08/23/2014
Hi there,
I meet all the system requirements from the error message below and still it doesn’t want to work. I don’t know what to do anymore so can put this on work. Any solution ? Can anyone tell me please why is not working ?
Thanks !
TR 6.8.3 – Error
Program Update Required
You are currently using Trojan Remover 6.8.3. This version
is not compatible with the latest database update – you need to update the program to version 6.8.8 or higher.
You can do this either by clicking on the Update button on the main menubar (ensure you are connected to the Net)
or by manually downloading and installing the Program Update available from the Updates page at: www.simplysup.com
points
Trojan remover fails to update the program
Trojan Remover is a protection software built for creating a security shield against Trojan type threats. It must be kept up to date with the latest database of Trojan information. Unfortunately, you’re currently using an older version which is unable to work with the latest database.
The latest Trojan Remover works with different system and core and the latest database was built using the structure. So, the newer one won’t match with older ones. All you have to do is to get the latest Trojan Remover.
Download Trojan Remover. After downloading, uninstall the older one first and then install the latest one. Then, update your software. It should give you the best security.
