Trouble in autocad architecture 201
I am trying to download AutoCAD architecture 201 using the Autodesk installer but the downloading has been stopped after 2 minutes.
I am trying again and again but fail to do so.
Can anybody please tell me Is there any way to continue the downloading?
Or any other way to install anywhere else?
Answered By 0 points N/A #193915
If you a problem is occurring during a download or the download doesn’t start at all, I’m sorry to inform you that you have been trying to download a damaged file.
The best and fastest solution for your problem is to try to find another AutoCAD architecture installer file. If you keep trying to download this file, you are just wasting your precious time.
I hope this was helpful.
Kind regards.
