malcdavid
Posted on - 01/29/2012
I'm publishing this concept after several problems in establishing my VPN network on my iOS gadgets (both my iPhone and iPad). The VPN network is operating incredibly well on my PC, so I think that the machine or my options (ID and passwords) are appropriate.
I have also tried to get some assistance from some of my friends but they are also unable to fix the problem. I guess, it would be better to publish my websites created in both PPTP and L2TP network method. Anyone could inform me where did I go wrong and how to address the issue.
Trouble connecting iOS devices with VPN network
The problem may be occurred from the VPN vendor or from your setting. If you are using any free VPN service then get any paid vendor service. For solving the setting problem, reconfigure the VPN setup. For L2TP settings, visit reference site. The PPTP setting is slightly hard but fruitful.
With my iPAD, the following were done configuring the VPN:
Select Settings > General > VPN
Choose Add VPN Configuration and input your data
Once this is done, you can configure the option to turn on or off your VPN on the main Settings menu
You may want to assess the user guide for your unit,
To check supported protocols,
I hope this also works for you.
