Trouble with Documentation ZIP File for Fusion Middleware 11g (11.1.1.6). Any help?
I just encountered a problem when I downloaded E23943_01.zip. It is the 2.5 GB documentation set for Fusion Middleware 11g (11.1.1.6), WebLogic 10.3.6. The WinZip won’t open the Zip file due to this error: too many entries in central directory according to end of central directory info.
At first, I was thinking maybe I was not able to download it correctly that is why the error message popped up. I again tried downloading it not only twice but thrice just to make sure to perfectly download it. I am not sure if the source E23943_01.zip file on Oracle's site is corrupted. Can you please tell me if I am thinking the right way? Or could you at least tell me how to get this problem solved?
