Trouble for DVD sharing for Mac to watch movies installation
I have a lot of stressing works every day, and I just want to relax for while with my MacBook Pro and watch movie on it, I installed DVD sharing for Mac to watch movies thinking it would play and it didn't, instead the error massage showed up.
I didn't know what to do, is there any effective solution regarding on this problem?
Answered By 0 points N/A #154850
I wish you posted the error message you received with your DVD. It’s not clear what kind of error you get while using it. If the problem is with the DVD application you recently installed then try checking its system requirements. Maybe the version you have is not compatible with your operating system or maybe this version is conflicting with some of the components on your machine.
Or maybe the installation didn’t go so well and different kinds of errors were encountered along the way. Try doing a clean installation of the program to fix any corrupted files that may be affecting the functionality of the application. Uninstall your DVD application then restart your machine when asked. After booting, check your computer for any possible errors. Use a disk utility application to check the system. Install the program again then check if this fixes the problem.
