I encountered an error while I was using the new version of Microsoft Office 2007, I installed this new version on my computer as a replacement from the old one I used; Microsoft Office 2003.
The error occurred when I was updating a schema.
Here is the picture:
Error:
Microsoft Office Word
One or more schemas you have selected cannot be used in this document. A
schema may not be available, may not be valid, or may require additional schemas in order to function correctly.
I don't understand this one, please help me guys.
Dplus
Trouble encountered in the new version of Microsoft Office 2007
Microsoft Office 2007 package you select cannot recognize as your PC system to use. Before your Office package will be remove and 07 registration code must be valid. For valid your apps you can join the latest and new version application. And schemas you select have to same as your installed product registration.
Or if you have Windows 7, Vista, or XP then text document must be contained default system. Sometime it make some difference inside problem like un-space in your drive or enough RAM. I am simply advising, you can use 2010 Office package for your betterment
Re-install your registration software.
Remove from 'C' drive which also have your before applications data. and restart your program.
It may help you to solve.
Tinah
The Microsoft Word you downloaded may be corrupted, and the only solution is to get another Microsoft Office 2007 and install two. Two there might have been a problem during installation.
Go start – control panel – add/remove program – right click on Microsoft office and select change- this is going to repair the Microsoft office.Â
mon47
Your MS Word 2003 wasn't fully uninstalled properly.
I guess that more times you should have to re-install your new software for computer operating system format.
This is your newly published MS Word version 2007.
I don't know exact date of release of MS Word version 2007 yet.
Maybe your software had been damage due to cause changing of recent climate. Thus you have been encountered with Schema. Look on the message from MS Office Word there you will able to find " Details" and you must click on it.
Then you must informed details at a time.Â
