Trouble upgrading to Norton 2012
Hello everyone,
I’m having trouble upgrading Norton 2012 Smart Virus Def. PreRelease. I’m using Windows 7 Professional and I have a fast network connection so I guess that couldn’t be the problem. Everything seems to be working properly until I try to upgrade and get this message:
“Norton LiveUpdate Summary
Item
Norton 2012 Smart Virus Definitions x64 PreRelease
Status: Failed to complete
Update Criticality: Recommended
More information”
I would be very grateful for your opinion.
Answered By 75 points N/A #94579
Hi Liam,
Instead of updating your norton antivirus say from a beta version to a full version, I will suggest that you just get a copy of the full version and perform a full installation of it on your system. Sometimes the antivirus brings problems when it comes to updating especially in the beta version.
If it refuses is still then I will recommend that you try a new antivirus on your system if you do not mind. AVG, Kaspersky and bitdefender are some of the strongest antiviruses that you might want to try using on your system for the offer best protection for the system
Hope this helps.
____
Lee Hung.
