Trouble using the header
Asked By 7060 points N/A Posted on -
Please check the code I wrote.
The results I get are "0 0 0 0 0 0 0 0 0 0 0 1 2 3 4 5 6 7 8 9 "
and what I expected is "0 1 2 3 4 5 6 7 8 9 "
Can anybody explain what the results?
Thanks
#include <vector>
#include <iostream>
using namespace std;
int main ()
vector <int> A(10);
for (int i = 0 ; i < 10 ; i++)
   A.push_back(i);
for (int i = 0 ; i < A.size() ; i++)
   cout<<A[i]<<" ";
return 0;
Answered By 0 points N/A #80682
You do not need to use as “vector <int> A (10);” it should be as “vector <int> A;”.  When we said it as 10, from the push_bach method occur problem that you faced. That why it printed like that. It will print the answer correctly from the 11th number.
This is the correct coding that can generate your answer.
#include <vector>
#include <iostream>
int main ()
vector <int> A;
    A.push_back(i);
   cout<<A[i]<<" ";
return 0;
I hope this will help you
