Trouble in windows washer, how can i clean my PC?
I am having a trouble with windows washer installed on my PC which is running on windows 7.
I also installed fire fox, but the problem still persists, I cannot clean my computer.
I will be grateful to any person who can help me or is there any software on how to clean my PC,
Thank you.
Best Answer by Alber grower
Answered By 0 points N/A #100360
There are many antivirus out there and has the same function as Windows Washer.
Both Offline and Online security, it could provide you both.
Try this software listed from priority to least priority:
  • Trend Micro – very strict in terms of using internet and adding illegal serials as well.
  • Kaspersky – very good anti virus.
  • ESET NOD 32 – good anti virus software as well.
Try using those three.
Trend Micro is the best because there is no counterfeit software of it and you really need to buy the genuine key of it.
PC-cilin Internet Security 2007 Window Console
Also always perform registry cleaning buy installing CCleaner for your computer.
Answered By 20 points N/A #100362
Hallo Andrea,
I will suggest for you two ways that you will use to clean your PC, and I recommend that you use them both:
1. Disk cleanup:
  • On your computer, click on start and then type disk clean up in the empty field.
  • Press enter to open disk clean up.
  • Choose the disk that you will like to clean, which should be C: by default.
  • Click OK.
  • Check all the files that you want to clean and then click OK.
  • Disk clean up will successfully clear all unused files on your system.
2. Ccleaner:
  • Download an application called Ccleaner and install on your computer (just Google for Ccleaner and download for free).
  • Launch and then select all the files that you want to clean and then click OK.
  • Also use Ccleaner to fix any registry issues and uninstall unwanted programs.
Mahesh Babu
Answered By 10 points N/A #100364
Hi
There are a lot of autoplay cleanup utilities available for Windows 7 like AutoRun CleanuUp Tool, CCleaner, Disk Cleanup etc.
For more helpful pay a visit this link : Is there a Windows 7 autoplay cleanup utility?
