I have a and graphics card in my PC, but when I bought the PC the ati catalyst control centre was not installed. I installed it manually but I am constantly getting an error while I try to launch it. Please help.
Trouble With Ati Catalyst Control Centre Error Solved
If you have an ATI Radeon graphics adapter that means your video card is from AMD. If you need to install the ATI Catalyst for your video card, the easiest way to get it is from the manufacturer’s website. Since you have an AMD video card, head down to AMD Graphics Drivers and Software to get the driver.
Here, search for your product from the list then click it to go to the download page. Download and install all available drivers and software applicable to your computer. The availability of AMD Catalyst Control Center depends on the kind of AMD video card you have. This means not every AMD video card requires the AMD Catalyst and the AMD Catalyst Control Center does not support all AMD video cards.
To get the latest AMD Catalyst driver for your video card, if it is supported, click the “Download” button under “Auto-Detect and Install Radeon Graphics Drivers for Windows.”
