phoenix suy
10 points
Posted on - 03/23/2012
I have troubles with sending files to the IGA. I am getting an error when I try to log in, receive or send files.The error codes recorded below are getting under the description group in the Outbox or Inbox section of the V1 Professional version 5.0 IGA window, or when trying to receive or send swing videos with the V1 Home or V1 Golf software. Need a solution.
Thanks in advance
Troubles with sending files to the IGA
Always keep it in mind that, heavy internet traffic can cause webpages to time out and created the error with error message. So you can use internet traffic control software or put an deeper view into the matter.
Here I suggest you at first to visit this site for knowing about the error message explanations then you will probably gain the ability to solve the problem your self.
Also here I give you a PDF link that must be make you understand about the solvency of your problem. https://semmes.com/wp-content/uploads/2016/07/insurance-guaranty-associations.pdf
Hope this all may work perfectly.
I think you can easily grab your solvency from the first way I suggest you.
