elsietbrown
20 points
Posted on - 03/15/2013
Hi techy. I’ve installed a far cry installshield wizard then this error appeared.
Error Number: 0x80040706
Description: Object reference not set
Setup will now terminate.
OK
How to fix this troubleshoot? What are the steps to have successfully installed this software?
Please help I really need this software to be installed. I’ll wait for the answer.
Thank you so much.
Troubleshoot of far cry installshield wizard.
HelloÂ
Make sure that your graphics card or driver supports shader model 2.0 or higher , if so try to update it with the latest update.
If it doesn't ,you have to buy another one that support that shader .
There is another solution , you may have an old version of the InstallShield engine on your computer , try to download the latest one and install it rightly .
I hope these solutions will fix your problems .
