What should I do when the plugin fails to load?
There might be cases of what the time Outlook Add-in will not do anything. This point will explain you what you can do to facilitate repairing data in Outlook. This detail or data will provide extra detail on the error and will really help 3CX Support.
This is the resolving solution I found somewhere but I am unable to figure it out can anyone help me with this.
Troubleshooting Plugin errors in Outlook occurred
Hi Timothy,
Did you set the CAS policy for your add-in?
your issues seems to caused from assembly not granted full trust.
About how to use caspol to grant full trust to Add in assembly, you can refer the following MSDN document.
Hope this helps!
I am able to recall that I encountered the same problem when I developed a simple Word 2007. I was able to resolve the problem you are encountering by downloading Microsoft Office 2007 Primary Interlop Assemblies from this link.
I hope the information provided will serve your cause and you may not face this problem in future.
