Troubleshooting on the software to open eyes in a picture
What should to do where some trouble shooting problem appear during using the software to open eyes in a picture?
If this is the first time that this happens with your software, try closing the application, restart your computer then try it again. See what happens after rebooting the computer. If there is no improvement and the problem is the same, try reinstalling the program to fix any corrupted files that may have developed in the system in the long run.
Uninstall the application then restart your computer when asked. After booting, check your computer for any possible errors. Use a disk utility application to check the system. For a much thorough diagnostics test on your machine, use disk utility applications like Norton SystemWorks, Norton Utilities, or PC Tools Performance Toolkit. Install the application again then see if this fixes the problem. You should also check the system requirements of the software to further analyze the problem.
