Troubleshooting Wi-Fi connections on iPhones, iPad, iTOuch
Connecting to the internet via WiFi connection requires a strong signal, but sometimes, you will experience difficulties in connecting to the internet. There are some factors affecting signal strength, connectivity issues, etc.
How are we able to find out which of these factors should be resolved first and connect successfully on the internet?
Answered By 0 points N/A #161805
The first thing that you need to do is to find WiFi signal. If you found one, it is about time to connect to it. There are lots of configurations for WiFi to put security so you need to consider those securities. Those securities sometimes required password. If you found connection, then connect to it, even you are not connected to it, it shows the signal strength. If the connection prompts for the password, so you need to enter correct password.
If you are already connected and there is a problem when you connect to the internet, you need to check the signal strength, sometimes it is the problem. But if the signal is strong and you can’t connect the problem is the connectivity. You may try some solutions like to use another device to check if there’s some error about the connection or to your device.
