Trp media converter crashes on Windows 8
I use TRP media converter to convert TRP files to mpeg and flv video files. The converter now crashes when launched ever since I upgraded my OS to Windows 8. Is there a work around or patch for this? Thanks.
Hi there
I read your question and I understood the problem. But I’m afraid that there is no solution for overcome this problem since windows is a touch based OS and still TRP media converter is not able to come up with a compatible version for windows 8. So you have to wait for some wile so obviously they will come up with a latest version.
Best of luck
Taylor B Campus
Thank you
Did you try reinstalling the converter? Remove the recent software driver and then download from the Windows 8 AppStore website below:
http://www.bing.com/search?q=windows8appstore
After the downloading process, reinstall with this new version and run it.
