True Crypt External Hard Drive Encountering Problems
After I try to mount one of my 1TB external USB hard drive with True Crypt encryption, there’s an error message which reads, “hdiutil attach failed no mountable file systems”. Then I cannot log-in even if my password is correct because there’s an error message which says “not a True Crypt or Incorrect password”. I always make a format to my eternal drives as bootable for Mac OS X Extended Journal. The True Crypt Volume is also bootable for Mac OS X. These drives have been working and turned on after I attached it to my Mac OS X. What do you think is the problem? Did Tux era expire already? Or do I need to update to the newest and full version? Or should I remove it?
