The Trust relationship between workstation and primary domain failed
I am unable to log in my system. I entered password correctly but also message displaying as "The Trust relationship between workstation and primary domain failed.
To get rid of the problem you will have to do the following:
First log on locally as a local administrator.Â
Go to control panel in the Network tool and select. After selecting enter a Workgroup name, leaving on the domain.Â
Restart your computer and again log on locally as a local administrator.
This time you will find two methods to rejoin the domain:
1. You are able to join the domain from the client if at the same time you are able to provide an administrator username and password on the domain.
2. You are able to delete the existing computer account in Server Manager, create the computer account again, synchronize the domain and then on the client rejoin the domain.
I think your problem has been solved.
Hathy
