Trusted root certification authorities store
How to manage trusted root certificate for a local computer? How to add certificates to the trusted root certification authority for a local computer?
Hi
To manage trusted root certificate for a local computer, the steps to be followed is as explained –
Click START Search and search for mmc. On the file menu click on add/remove snap-in. using available snap-ins click Local group policy object editor, click add and edit the policy in the computer which you desire to edit. To add more snap-ins, in the console tree go to Local Computer Policy, Computer Configuration, Windows Settings, Security Settings, and then click Public Key Policies Double-click Certificate Path Validation Settings, and then click the Stores tab. Select the Define these policy settings check box. Under Per user certificate stores, clear the Allow user trusted root CAs to be used to validate certificates and allow users to trust peer trust certificates check boxes. Under Root certificate stores, select the root CAs that the client computers can trust, and then click OK to apply the new settings.
To add more certificates follow the same step as START search and search for mmc. Then click on add/remove snap-ins and then click on Certificates in Available snap-ins and click on add to add more certificates for the local computer.
Notifications
